IPButton - Text can not be changed from Arduino
Posted: Thu Oct 18, 2018 1:20 pm
by yum
I play around with the "TurnLEDOffAndOn" example and augmented the code by:
void SendToIPButton1()
  MyPanel.ShowControl(F("IPButton1"));
  // my added code line:
   MyPanel.SetText(F("IPButton1"),F("uhu"));
but the text of the button does not change - the interface says
Text doesn't exist in IPButton1
... but of course Text is a member of the button class.
Here is the serial log:
MegunoLink Pro - Turning and LED on and off
!ToggleLED
Got ToggleLED command.
{UI|SET|IPButton1.Visible=True}
{UI|SET|IPButton1.Visible=False}
{UI|SET|IPButton1.Text=uhu}
{UI|SET|IPButton1.Enabled=True}
{UI|SET|IPButton1.ForeColor=Red}
{UI|SET|IPButton1.BackColor=Blue}
Re: IPButton - Text can not be changed from Arduino
Posted: Thu Oct 25, 2018 3:36 am
Hi Yum, currently the text on a button is a design time only property. I'll add it to the feature request list.
