Textbox, Command and Parameters.NextParameter()
Posted: Sun Dec 15, 2019 9:42 am
In visualiser I am using Textboxs for the user to enter data. I want to be able to obtain the string values and save them to a csv file.
The way I am trying to achieve this is to;
1. obtain data from textbox in key/value pairs and pass it back to Arduino via Serial Command.
2. obtain the data via Parameters.NextParameter(), parse the data, format, etc in Arduino
3. pass it back to the visualiser via a dedicated Messenger Monitor
For example, I have multiple Textboxs eg Project, Location, Address, etc
I will describe the issue for a single Textbox "Project", where a user could type "XYZ drilling project".
The text is obtained via a command initiated from a Button
The command is as follows !SaveProjectData [IPT_Project.Text]\r\n
The serial monitor displays the following text when the Button is pressed !SaveProjectData XYZ drill project
In the Arduino, the command "SaveProjectData" calls Parameters.NextParameter().
Nothing is subsequently displayed in Message Monitor.
The issue appears to be that Parameters.NextParameter() use a space as delimiter.
The only way to obtain the string data is to cut it back to "XYZ" then it will work ie Steps 1 - 3.
Ideally I would like to able to use a Command and pass all of the Textbox strings eg Project, Location, Address as key/value pairs
eg !SaveProjectData [IPT_Project.Name]=[IPT_Project.Text]|[IPT_Location.Name]=[IPT_Location.Text]|[IPT_Address.Name]=[IPT_Address.Text]\r\n
I think a solution could be to have a user defined delimiter eg "|" so that key/value pairs can be obtained.
I have searched the forum and cant find a solution.
Suggestions/ideas would be appreciated.
Leon
Leon
