Visualizer just showing values
Hi Joe, check out this example in our Arduino library.
https://github.com/Megunolink/MLP/tree/ ... /SendToMLP
If you look on line 40 of this file you can see the textbox named "Status" is being set to display "Start".
https://github.com/Megunolink/MLP/blob/ ... dToMLP.ino
The only other thing to remember is that when constructing the interface panel you need to drop in a MLPUIMessageProcessor from the toolbox in the interface designer. This page has more clues for doing that
http://www.megunolink.com/documentation ... ace-panel/
Once you add your text boxes and MLPUIMessageProcessor you should be able to update them from the Arduino.
Hope this helps
Hope this helps
